igor1234 Postat Octombrie 28, 2016 Share Postat Octombrie 28, 2016 Gaby, mi te inchipui peste 20 de ani, pe un forum oarecare: "Pai pe vremea mea DSD era la putere. Legea era facuta de monstrii gen LampizatOr, Playback Design, MSB, nu de necunoscutii de azi". De existenta lampilor vei fi uitat de mult. Citează Link spre comentariu Distribuie pe alte site-uri More sharing options...
robespier Postat Noiembrie 11, 2016 Share Postat Noiembrie 11, 2016 Norton: Have you ever been tempted to design tube products? Pass: I have designed tube products, but they've never wandered outside the lab. I like tubes; I have no problem with them. Because there are limited varieties and because they only come in one kind of device—what you think of as an n-channel type of device—you're limited in the number of ways you can use them. So large numbers of potential topologies are not available to you. As a topologist, they become less interesting to me for that reason. But I've designed tube amplifiers, preamps, and crossovers. To market them would not be consistent with the activities that Threshold is involved in, and we're not really looking to have people ask me why I'm doing tubes when they've come to expect solid-state, and so on. But I have a number of thoughts about tubes. The most fundamental is that they enforce, in design, one of the basic tenets that I hold dear: that, all other things being equal, simple circuits sound better. You can't put 57 tubes under the hood of a preamp. But of course you can do so in an IC, which typically has a large number of devices, or even with discrete solid-state. I work very hard to enforce simplicity as part of the design process, and tubes can even take an inept designer and at least see to it that he doesn't make his design too complex. Read more at http://www.stereophile.com/content/nelson-pass-simple-sounds-better-page-4#Xyyrg5oM7CsWpLA1.99 Citează Link spre comentariu Distribuie pe alte site-uri More sharing options...
hersorin Postat Noiembrie 11, 2016 Autor Share Postat Noiembrie 11, 2016 Pentru ca mi-a dat apa la moara Sith ,va mai spun o faza ,care ma enerveaza maxim !Foarte des sunt intrebat : care tub "se aude mai bine " ECC81 sau ECC83 ,EL34 sau KT88 ?? Astea sunt doar exemple luate aleatoriu ,intrebarile sunt cam despre toate tipurile de tuburi folosite in audio. De ce ma enerveaza ? Pentru ca degeaba ii explici bizonului ca un amp /preu este un tot unitar si fiecare tub este pus in schema acolo unde se pot obtine performantele cele mai bune ,el iti f..e creierii ca a citit,a auzit ,a...,a.... ca tubul x suna ,cinta,amplifica mai bine decit tubul y . Stii de unde vine in general intrebarea? De ex. Unison Research foloseste unele modele de lampi pe cind Audio Research altele. Audio Research e mult mai bine cotata deci automat lampile folosite sunt mai bune (ECC82 din UR e mai slab ca ECC88 sau sa nu mai zic de supertubul 6H30 din AR). Citează Link spre comentariu Distribuie pe alte site-uri More sharing options...
hersorin Postat Noiembrie 11, 2016 Autor Share Postat Noiembrie 11, 2016 Nu mai zic de tubul 6463 folosit in preul Tenor Audio . http://www.radiomuseum.org/tubes/tube_6463.html The Best . Citează Link spre comentariu Distribuie pe alte site-uri More sharing options...
hersorin Postat Noiembrie 11, 2016 Autor Share Postat Noiembrie 11, 2016 Pai ti-am explicat mai sus . De acolo se porneste . Unison Research mai slab cotata decit Audio Research . Citează Link spre comentariu Distribuie pe alte site-uri More sharing options...
hersorin Postat Noiembrie 11, 2016 Autor Share Postat Noiembrie 11, 2016 Eu am inteles cum sta treaba dar multi se uita la ce ziceam eu mai sus . Citează Link spre comentariu Distribuie pe alte site-uri More sharing options...
hersorin Postat Noiembrie 12, 2016 Autor Share Postat Noiembrie 12, 2016 Acu 5-6 ani si eu eram sigur ca ECC88 sunt mai bune decit ECC82 si cele mai bune lampi sunt Mullard . De altfel Mullard au si fost primele lampi cumparate (macar acum costa de 3 ori mai mult ) . Asta iti ofera unele forumuri si chiar celebrul forum DIYAudio . Daca nu discuti cu cineva care se pricepe cu lampile uite ca traiesti cu fel de fel de timpenii citite pe net . Citează Link spre comentariu Distribuie pe alte site-uri More sharing options...
hersorin Postat Noiembrie 12, 2016 Autor Share Postat Noiembrie 12, 2016 Sa iti dau si un exemplu gasit imediat . de pe diyAudio " First, the 12AU7 is non-linear. OTOH, the 6SN7, and its immediate relations, is among the most linear amplifying devices, ever. The JE Labs 76/6SN7 is a big step up in clarity, tone and texture. " Deci daca citesti asa ceva pe forumul marilor ciocanari de pe planeta , ce concluzii poti trage ? Si exemplele sunt multe , foarte multe . Citează Link spre comentariu Distribuie pe alte site-uri More sharing options...
hersorin Postat Noiembrie 12, 2016 Autor Share Postat Noiembrie 12, 2016 Alt criteriu prin care iti ei teapa cu lampile . Dintre citeva lampi de preamplificare produse/vindute de celebrul Genalex , care credeti ca sunt cele mai scumpe ? Se stie ca in popor ce este mai scump = mai bun Citează Link spre comentariu Distribuie pe alte site-uri More sharing options...
hersorin Postat Noiembrie 12, 2016 Autor Share Postat Noiembrie 12, 2016 Mai este una tare ,alergatul dupa anumite marci de tuburi;de exemplu toata lumea vrea tuburi Telefunken,putin stiu ca tuburile cu adevarat Telefunken au un indiciu pe care alte tuburi Telefunken nu il au ,cele facute in fabrica Telefunken au pe partea cu pinii ,pe sticla, o stanta din turnarea sticlei ,un romb. Intre audiofili acel romb se numeste Diamond . Asta este . Citează Link spre comentariu Distribuie pe alte site-uri More sharing options...
gionloc Postat Noiembrie 12, 2016 Share Postat Noiembrie 12, 2016 Cei de la Audio Note folosesc tuburi Telefunken. Oare, de care ar fi ? Cei de la Audio Note nu folosesc tuburi nos in aparatele lor. Oto SE vine cu Sovtek, cdplayerele la fel... 2a3 tot sovtek. Doar la unele modele de amplificator - cu 300B sau 45 - ofera ca posibilitate de a cumpara in pachet suplimentar tuburi NOS: Western Electric la 300b, la 45 nu mai stiu (la ampliful Paladin, cred ca poate fi verificat ce ofereau). Cred ca singurul comerciant de aparatura cu lampi care foloseste exclusiv NOSuri (aproape toate piesele) e Shindo. Citează Link spre comentariu Distribuie pe alte site-uri More sharing options...
hersorin Postat Noiembrie 12, 2016 Autor Share Postat Noiembrie 12, 2016 (editat) The JE Labs 76/6SN7 is a big step up in clarity' date=' tone and texture.[/b'] " Este parerea omului despre ce a auzit el cind a montat 6SN7 (6H8C cod rusesc) in loc de ECC82 ,poate trebuia sa mai bibileasca la schema cind avea montat ECC82 ,treaba este subiectiva . Dar nu poti sustine ca ECC82 este superior ca sound fata de 6SN7 sau invers . Si pasul ala mare in claritate , ton si textura la ce se refera oare ? La sticla din care sunt facute ? daca nu la sunet ? Eu bizonul prost asta am inteles , se refera la sunetul lampilor respective . Editat Noiembrie 12, 2016 de Vizitator Citează Link spre comentariu Distribuie pe alte site-uri More sharing options...
gionloc Postat Noiembrie 12, 2016 Share Postat Noiembrie 12, 2016 Exact, Sau la modele super scumpe. Si in dacurile 4.1 si 5 Special folosesc nos-uri... Citează Link spre comentariu Distribuie pe alte site-uri More sharing options...
hersorin Postat Noiembrie 12, 2016 Autor Share Postat Noiembrie 12, 2016 Mai scriu ceva sa clarific unele scapari ale mele . Am tot spus ca imi plac lampile Brimar , apoi Philips etc. Sa nu se inteleaga ca una e mai buna ca alta este fix aceeasi chestie intre a alege un mar Golden si un mar Ionathan . Eu prefer Ionathan dar maninc cu placere si un Golden . Citează Link spre comentariu Distribuie pe alte site-uri More sharing options...
hersorin Postat Noiembrie 13, 2016 Autor Share Postat Noiembrie 13, 2016 Evolutia inscriptionarii Mullard Citează Link spre comentariu Distribuie pe alte site-uri More sharing options...
hersorin Postat Decembrie 25, 2016 Autor Share Postat Decembrie 25, 2016 O constructie total noua . Oare sa va merge spre mai bine ? http://www.effectrode.com/techtube-blackburn-e813cc/ Citează Link spre comentariu Distribuie pe alte site-uri More sharing options...
hersorin Postat Decembrie 25, 2016 Autor Share Postat Decembrie 25, 2016 Si se pare ca si Telefunken revin in varianta audiofila . Citează Link spre comentariu Distribuie pe alte site-uri More sharing options...
hersorin Postat Decembrie 25, 2016 Autor Share Postat Decembrie 25, 2016 Si pentru ca am fost cuminte dimineata asta mosul mi-a adus inca o pereche de Philips ECC186 . Cica sa mor inconjurat de lampi . A mai venit si cu un Pickup JVC L-F41 si peste 200 placi (destul de uzate) , oricum doar lampile ma intereseaza . Citează Link spre comentariu Distribuie pe alte site-uri More sharing options...
hersorin Postat Decembrie 25, 2016 Autor Share Postat Decembrie 25, 2016 Ascult de dimineata Philips ECC186 si pot spune ca au cel mai Live , Viu sunet auzit de mine dintre toate lampile . Daca pe Mullard si Brimar Sara K are orice distanta fata de ascultator cu Philips iti cinta in brate . Acum mai caut si aceste raritati . Citează Link spre comentariu Distribuie pe alte site-uri More sharing options...
hersorin Postat Decembrie 25, 2016 Autor Share Postat Decembrie 25, 2016 Acestea sunt . Citează Link spre comentariu Distribuie pe alte site-uri More sharing options...
hersorin Postat Decembrie 25, 2016 Autor Share Postat Decembrie 25, 2016 Si aici e topul unui pasionat de tuburi Ecc82 . Si nu am nici macar una . Mare este lumea lampilor . Citează Link spre comentariu Distribuie pe alte site-uri More sharing options...
hersorin Postat Decembrie 25, 2016 Autor Share Postat Decembrie 25, 2016 Stie cineva mai multe despre aceste lampi ?(poate Vio) Marconi B329 is the British equivalent numbering of the much-hyped, and very expensive, Genalex B749, a select 12AU7 made for British GEC only by Mullard. Typically a long-plate Mullard if early vintage, an excellent sounding tube - but really no different than a Mullard of that vintage . Marconi B329 will be Mullard or Brimar manufactured ECC82 , Marconi was just another marketing brand of GEC (Osram , Marconi , Marconiphone etc) Citează Link spre comentariu Distribuie pe alte site-uri More sharing options...
zal Postat Decembrie 25, 2016 Share Postat Decembrie 25, 2016 De la o anumită raritate şi vechime devin piese de muzeu, ar fi o crimă să mai funcţioneze. Citează Link spre comentariu Distribuie pe alte site-uri More sharing options...
hersorin Postat Decembrie 26, 2016 Autor Share Postat Decembrie 26, 2016 Pai pentru mine doar sunetul conteaza , nu anul fabricatiei . Daca imi functioneaza minim 8 ore sa ii inteleg tipologia de sunet o pot trece la colectie . Sincer o lampa moarta doar ca e foarte rara sau veche nu ma intereseaza , nu sunt colectionar de obiecte sunt colectionar de sunet . De altfel asta este si marele atuu al lampilor , iti poti face singur sunetul preferat . Nu cred sa existe propritar de electronice pe tuburi care sa nu aiba minim o pereche de tuburi de rezerva sau sa nu fi testat minim o pereche de lampi diferite de cele de uzina . Si sa mai pun o frumusete de tub care mi-ar place sa il ascult . Citează Link spre comentariu Distribuie pe alte site-uri More sharing options...
fane079 Postat Decembrie 26, 2016 Share Postat Decembrie 26, 2016 GEC-ul este ef 86 ? Citează Link spre comentariu Distribuie pe alte site-uri More sharing options...
