Naim cd5si defect
adyy35
Posibil sa fi crapat partea de audio output.
Acest aspect se poate intimpla daca cumva a scos si reintrodus cablurile Jack RCA cu aparatul in priza, descarcare capacitiva prin impamintare si condensatori de recucere EMI.
Roaga-l sa puna niste poze de calitate si rezolutie, cu aparatul desfacut, sa vedem ce este acolo; se repara in principiu.
Iesirea analogica e selectata corespunzator din soft? Adica DIN sau RCA (phono), in functie de caz?
Dupa verificarea acestui lucru revino; vezi manual de utilizare.
https://www.naimaudio.com/sites/default/files/products/downloads/files/CD%20Players%20English%20Iss%208C.pdf
16.4 Output Socket Selection
A pair of RCA Phono output sockets are fitted on CD player
rear panels to provide an alternative to the preferred DIN
socket. Proceed as follows to select the RCA Phono sockets.
With the player stopped, press and hold the remote
handset
disp
function (handset in CD mode) or, if fitted,
the player
disp
button until the CD player prog indicator
flashes. Further operations of the
disp
function will now
cycle through each combination of the two socket types
(DIN only, RCA Phono only or both). The selected option is
indicated on the CD player display as shown below.
Socket Option
Player Display
DIN
O
Phono
O O
Both
O
O O
Press and hold the
disp
function a second time to exit from
socket selection mode.
To avoid compromised sound quality, do not select
both
unless their simultaneous
multumesc tuturor
Jack mai ales tie
asa s-a rezolvat , din telecomanda
cred ca a fost vreun soc si s-a resetat la valorile din fabrica
a trebuit ales din nou modul pe care are iesirea semnalului
mersi inca o data
Acest topic este acum închis pentru alte răspunsuri.
