bibi Postat Iunie 9, 2014 Share Postat Iunie 9, 2014 Citează Link spre comentariu Distribuie pe alte site-uri More sharing options...
bibi Postat Iunie 9, 2014 Autor Share Postat Iunie 9, 2014 Inspiration Series ... available june 2014 ... fully balanced design ... same design as Reference and Performance series AMP 1.0 ... stereo power amplifier ... 10,000 $ ... 200 W / ch into 8 ohms | 400 W / ch into 4 ohms @ 0.2 % THD+N ... bandwidth 10 Hz - 100 kHz @ 0.5% THD+N ... S/N ratio . 95 db, A-weighted MONO 1.0 ... mono power amplifier ... 20,000 $ / pair ... 400 W / ch into 8 ohms | 800 W / ch into 4 ohms @ 0.2 % THD+N ... bandwidth 10 Hz - 100 kHz @ 0.5% THD+N ... S/N ratio . 95 db, A-weighted PREAMP 1.0 ... line-stage ... 9,000 $ ... bandwidth 10 Hz- 100 kHz @ 0.1% THD+N ... S/N ratio > 105 db, A-weighted ... output = 17 V RMS ... inputs: 3 x XLR balanced, 3 x RCA unbalanced http://www.constellationaudio.com/ca/inspiration/index.php Citează Link spre comentariu Distribuie pe alte site-uri More sharing options...
