PS Audio «news»
bibi
DirectStream DAC ... digital to analog converter ... converts all digital inputs, including PCM, to 1-bit DSD ( utilizes 66-bit fixed-point FIR filters ) ... passive output stage: high speed class A video amplifiers are used as the final switch for the single-bit, double DSD output feeding a high performance passive audio output transformer ( act as both the galvanic isolation between the DAC and the outside world as well as the primary low pass filter ) ... built-in volume and balance control ... one single master clock designed by Crystek ... asynchronous USB input ( 24 bit / 192 kHz) ... optional Network Bridge ... polarity (phase) control
  • 2 weeks later...
Sprout ... all-in-one integrated amplifier ... 800 $ ... 8Ω 33W, 4Ω 53W (1KHz, @1% THD) ... Inputs: Phono (Moving Magnet), Analog, USB (asynchronous 192/24), Digital Coax (any sample rate and bit depth up to 192kHz 24 bits), Apt X Bluetooth (built in) ... Headphone output 16Ω 500mW, 300Ω 425mW ... S/N Ratio (A-weighted) >90dB ... funded by Kickstarter campaign
< sursa: UltraHighEndReview.com >
