bibi Postat Iunie 4, 2014 Share Postat Iunie 4, 2014 Citează Link spre comentariu Distribuie pe alte site-uri More sharing options...
bibi Postat Iunie 4, 2014 Autor Share Postat Iunie 4, 2014 RCD-101 ... CD-player / DAC ... replace RCD-100 ... uses a heavily modified Sony SACD drive ... new USB interface - supports DSD, no driver recquired ... AES/EBU input / output http://www.vitusaudio.com/en/128600-RCD-101 Citează Link spre comentariu Distribuie pe alte site-uri More sharing options...
bibi Postat Iunie 4, 2014 Autor Share Postat Iunie 4, 2014 SM-011 ... mono power amplifier ... replace SM-010 ... 400 W / 8 ohm - 800 W / 4 ohm ... SNR < 110 dB ... THD+Noise < 0.01% ... freq. response > 800 kHz ... Input (XLR / RCA): sensitivity 1.3 VRMS / impedance 10 kohm / slew rate 35 V / µs ... 1.4KVA UI transformers with <2% loss ... 240.000uF capacitor bank ... Zero global negative feedback ... 2mm thick boards with 105µm copper on all layers http://www.vitusaudio.com/en/128612-SM-011 Citează Link spre comentariu Distribuie pe alte site-uri More sharing options...
